New Metra 99-7803G DD dash kit
5 reading
92K views 186 replies 42 participants last post by  hightechredneck
#1 ·
Overall I'm pleased with it. There are three things I don't like though.
1. The mounting brackets are plastic. I had no problem installing it but it doesn't seem like it would hold up well if you need to take it out often.
2. The AC/Heater controls won't turn on just by pressing the corresponding button. You have to hit Auto first to turn it on. For example, if I wanted to turn on just the rear defogger, I can't just hit the rear defogger button. I have to hit Auto first, to turn the unit on, then hit the rear defogger.
3. The thing I dislike the most is that the buttons do NOT light up! The screen is the only thing that illuminates. This makes using the unit at night difficult. I have to turn my overhead light on to adjust anything. Maybe with time I'll learn the button locations by feel and will be able to use them in the dark but until then it will take some getting used to.
Here are a couple pictures.
#62 · (Edited)
Finished Install
I finished the install of my single DIN with pocket. I was able to get the factory cubby to work using the following modifications:
1. For the single DIN with pocket you do not need to remove the entire dash support but only need to remove as much as shown in the attached photo. The pocket clears just fine.
2. You need to cut off the corners of the radio mounting brackets as shown in the photos so that the cubby door will clear while opening. Why METRA didn't do this I do not know. Also, looking at the clearances, I am not convinced that the Double DIN wouldn't fit and have the cubby work. You might have to clearance the dash support a little more but I think the cubby door will still work. Someone may want to try and see....
Also attached are photos of the completed installation with both the cubby door closed and open. I think it looks pretty good and certainly much better than as received from METRA. Given the number of pattern and colors available for hygrographic printing, there are unlimited possibilities.
#63 ·
Overall I am pleased with it but if I had to do it again I might choose a different shade of burl. The shade I chose (WPT-496) has a little too much red/orange in it for my grey interior. The photos exaggerate the effect and it is not as noticable in person.
However, I think that a pattern that is more towards brown or grey would probably look better....
#71 ·
I sold my cubby door. Sorry.
Also I was wondering do you guys have the issue of the unit suddenly blowing cold air instead of warm air? It was happening to me Saturday. Really pissed me off since it was 20*F and I had to drive for 3hrs.
#77 ·
Metra Honda Dash 99-7083G
I just ordered this from Crutchfield. The regular price is $249.95, but it's half price if you order a compatable stereo with it. I ordered the cheapest stereo they had for $69.99, which still allowed me to save $50 or so off the dash. I entered a Crutchfield coupon code - 3A184 - and saved $20 more. I got the dash, a JVC stereo, the mounting kit for $189.99. Thanks for the heads up on the half price dash from Crutchfield whomever it was!!!
#78 ·
I just installed this dash kit with the double din pioneer avic-940bt. As of right now I still have my stock cubby but obviously it's inoperable. I got the pocket on order. I haven't had any issues with it at all. When I first connected it, it was blowing cold air. But once I rehooked my battery after sub install its been working perfect ever since. I also got the stereo and the dash kit LCD all matching red like the rest of the lighting on dash. I also got it for half price through crutchfield. Ordered interior speakers elsewhere. So far I'm happy with it and glad I can have a double din in that location.
#90 ·
The bottom install is super easy. There are two white clips on the top of the cubby that just snap in and two screws on the bottom of the cubby. The clips and screws use the same mounting points as the OEM cubby. So like I said, it is super easy to install.
I did reuse the stock cubby door. I used magnets to get it to stick on. Looks cleaner than velco in my opinion.
