1 - 2 of 2 Posts
I’m trying to fix my my moms ac. I replaced the compressor with a oem replacement and oil, condenser was replaced, and thermister replaced. Had tech pull a vacuum and add Freon and clutch will not engage. Checked power at compressor plug and have nothing. Checked fuses and they are all good. Swapped relay with fan relay that is working and no change. I did try and jump the low pressure switch and the engine kind of bogs down like it kicked in but clutch did not engage. I put power directly to the clutch and it does engage. Blower motor works at all speeds. Anyone know the reasons for power not to be sent to the compressor? Or maybe I didn’t jump the low pressure switch correctly if someone could advise me, it’s a 4 wire one. Thanks
2006 Honda Accord EX 4 door 3.0 V6
1 - 2 of 2 Posts
