1 - 20 of 31 Posts
orange county, socal
brand new piece in box. comes with all the stuff such as the brackets. looks exactly like the pic posted.
fits honda all accord 1994 - 2000
only $100.00
Engine Damper
Color/Finish: Blue
Product Description: Engine Damper mounts in between your vehicle's engine block and firewall to effectively control horsepower and torque. Keep your motor supported as you slam through those gears while adding a nice show piece under the hood.
blue color
clean and simple
fluxcapcaitor said:
does it work effectively when say the car is shifting? (when engine moves because it is shifting)
BUMP for you :)
white is correct to answer. this piece helps reduce the vibration while you are running hard. it contains both street and race bushings as well. helps with putting power to the gears rather then to have it go to the bushings alone.
Discussion Starter #9
i have never installed one before either. but as far as i can tell from installation manual its against the firewall to the engine block.
hmmm.... so this is sorta like them after-market polyurethane engine mounts? but instead of buying (non-existing) after-market engine mounts, the nrg engine dampers would be a good replacement/addition? very interested =) still researching, people over at honda-tech said it works.
Discussion Starter #11
yupp yupp! get this before someone else takes it, let me know asap. only one and brand new.
Interested...btw, is this a direct bolt on? so no drilling required right?
Discussion Starter #14
as i was looking at the instruction i dont believe there is any drilling needed.
i dont have that car so i couldnt tell for sure. i would assume not cause it is fully adjustable. very tight unit.
Discussion Starter #15
thanks for all the pms. i am trying to get 100.00 for this item being its pretty new to the market and this is a brand new item. it looks great and adds uniqueness to the engine bay.
are you sure it fits v6 as well? cause the nrg site doesn't say all accord it just says accord 94-00 i'm confused... need to contact them, sorry just want to make sure; cause i'm very interested lol
Discussion Starter #17
you might want to let me know very soon today cause i have some one who might be send me money real soon. again anyone who flows me the money first ill sell too.
949 since you are the seller of this product shouldn't you be doing your research on this besides slowaccord01?
Discussion Starter #19
no. i have already given all the info i have and also the the site. any additional questions i have also answered with what info i have. i am not the store.
1 - 20 of 31 Posts
