1 - 8 of 8 Posts
Does anyone know if the outside temp gauge will still work if i swap a coupe bumper onto a sedan and if also the coupe fog lights will work too?
Junior Member
i believe fog and temp will work together only on the EX models regardless of coupe or sedan. as for the fogs lighting up you should check to make sure it uses the same harness plugs. other than that everything should be ok
If the fogs are FACTORY installed then you can install the Temp gauge. I guess YOU cannot install BOTH if one or the other did'nt come stock.
NOt sure why because I want the temp gauge but I installed the fogs myself. I'm almost wanting to try but dont want to be out $100 for the temp gauge if it don't work!
arom said:
If the fogs came stock, then you can add the temp gauge.
If the car came with the foglights right from the dealership, they still plug into the same accessory port. The foglights don't come hardwired into the car like the EX alarm system and EX-L/EX V6 temp sensor.
1 - 8 of 8 Posts
