1 - 20 of 62 Posts
Time to part out the Accord to move onto a new car for 2011. Tons of things from car to sell. Here is the first thread of stuff to sell. All the parts came right off of car, so slightly dirty, but nothing is damaged. Everything is in good working condition. Just needs a slight degrease.
P2R Custom 4 Inch Intake Tube
SOLD
07 TL-S Camshafts
SOLD
Progress Rear Sway Bar
SOLD
Rear Big Brake Kit
This is a 12.2 inch rotor i believe. Uses stock calipers. For sure fits 98-02 Accord V6. Not sure what else if fits.
Asking $205 Shipped
Front Big Brake Kit
SOLD
Ported Runners
SOLD
Bored J32A2 Throttle Body
SOLD
P2R Throttle Body Spacer
SOLD
MDX Intake Manifold Velocity Stacks
SOLD
Ported J32A2 Intake Manifold
SOLD
P2R Power Plenums. This is a custom set of plenums. They weight about 1 pound lighter than our stand plenums.
SOLD
Automatic 1999 Acura TL ECU with immobolizer removed
$120 Shipped
2006 TL Clutch Slave Cylinder. Check valve removed.
SOLD
2006 TL Starter with Gold Reflective Heat Tape
SOLD
Braille 11.5 Carbon Fiber Battery
$145 Shipped
Brand New Braille 11.5 Battery
SOLD
Set of 6 J37 Rods from Acura MDX (Brand New)
Honda no longer sells these rods.
$225 Shipped
2 Enkei RPF1 wheels 17 x 8.5. Comes with Toyo 888 tires, but they are pretty low already.
$345 Shipped
98-02 Accord Coupe Seibon Carbon Fiber Hood. Hood is in great condition; however it is painted. This part is local pickup only.
$300 Local Pickup ONly. (South Florida)
J32A2 Wrinkle Red Valve Covers
Minor scratches in areas you should not see when on vehicle
$85 Shipped
GoPro Wide Angle Camera
SOLD
ARP Head Studs Brand New
Fits 90% of J Series Engines
$275 Shipped
Brand New ARP Rod Bolts
Fits most J Series Engines. You wont find these anywhere. ARP does not even offer these at the moment.
$250 Shipped
Axles. These were a spare set.
$75 Shipped. Should fit 99-02 Accord V6 , 99-03 TL & 01-03 CL
Boomslang VAFC2 Extension Harness (Brand New)
$100 Shipped
Coils off of J32A2 Engines
$20 Shipped each
Stock Fuel Psi Regulator
$24 Shipped
Custom Set of CP Pistons for J35 Engine
Can be used in a J32A2 with J35 crank and rods.
12.5:1 Compression. Custom X Forging. Internal Milling. Gas Ports, Gold Top Coating, 327 grams each.
$1,450
Brand New STACK RPM Gauge
SOLD
New OEM Honda Engine Mount Timing Belt side Bracket for J32A2 engine.
$25 Shipped
2 x Rota Boost 16 x 7
5 lug
$150 Shipped for both
Brad
How flexible are you on the price of the hood? Is the underside painted as well? Just curious, I guess at that price I could probably buy it brand new for a few bucks more and not have to deal with respraying it.
Willing to work out a deal on the hood for sure. The underside is not painted. There are also 4 holes on the hood from the hood pins. Yea just shoot me an offer.
Super IcyAccord
are there any cons to the braille batteries? like starting issues / charging? i am also running an audio system that i dont want to underpower.
┌∩┐(◣_◢)┌&#874
What would the advantages of Mdx velocity stacks compared to mine that r Oem j32a2 matched to the bored plenum I got? And those rods? Any mods to fit em? Forged?
✠ 2nd Amendment'r ✠
maybe interested in the TB and unused battery if you still have them after christmas time. In the mean time, subscribing to watch for more parts being put up.
Dont recommend it if you have a audio system. Cold Cranking Amps are low. so they dont like when you run anything with car off.
Discussion Starter #12
Innovative Mounts with 85A bushing. Those will be up for sale by Monday or Tuesday. Once we get them out of the car. Going to be asking $190 Shipped.
✠ 2nd Amendment'r ✠
Are these parts coming off the motor that made the 302hp?
Discussion Starter #17
Yes all these parts came off the 302 Hp engine. Velocity Stacks are sold already. The J37 rods can be used on any J37 crank. Can be used in any J series engine.
1 - 20 of 62 Posts
