1 - 4 of 4 Posts
Hi guys,
I am selling a brand new PLX wideband o2 sensor, never installed or out of the box. I just bought it a couple of weeks ago for my project and i am buying the F.A.S.T. XFI ems and comes with an o2 sensor, so i don't need this one. I paid $300, trying to get my money back or best offer. PM me if interested. Thanks
4.0L
what exactly does this do? just replace the stock o2 sensor? any benefits to this one versus stock?
This wideband sensor kit is a MUST for anyone who is serious about proper tuning, running big boost and doing it all SAFELY! A wideband O2 sensor kit serves two purposes: First, it is the single most important tool for tuning your air/fuel ratio and second, it is an insurance policy for your motor if you pay attention and use it properly. Wideband O2 sensor kits can be used in any gasoline powered internal combustion vehicle to assist in tuning the Air / Fuel Ratio for optimal economy or power. The info delivered by the wideband sensor can significantly improve the longevity of a turbocharged motor by letting you know when the ratio is running too lean (or rich for that matter). This information is VITAL if you are using or planning to use a piggyback fuel computer (such as an Apexi SAFC2). BE SURE YOU READ THE INSTALLATION INSTRUCTIONS CAREFULLY BEFORE INSTALLATION
Bosch controller with display
Ideal for affordable AFR monitoring.
Key Features:
Works with standalone engine management systems.
Accurate Air/Fuel Ratio <0.1, Fast Reaction
Advanced Sensor Self Calibration Circuitry. No manual calibration required.
Wideband LINEAR Analog Output (0-5V)
Narrowband Analog Output (0-1V)
Replace your stock Narrowband sensor.
32 MHz Advanced DSP Technology
Built in Resettable Fuse (No external fuse needed)
Sensor soft start circuitry, prolongs o2 sensor life.
Compact and Professional Design
"Plug and Play" Installation
ISO 9002 Certified Assembly
1 - 4 of 4 Posts
