1 - 4 of 4 Posts
The Jester
Working on 180k miles here and have lots of weird noises coming from the tire area. I'm sure to most people who have had these cars for a while you will know what parts are likely to break and wear out, seeing as this part of the car has never been serviced.
If there is a part to replace that could possibly be broken down there, I want to replace it. Get this thing riding like new. New sway, suspension, trans on the way, may as well get this taken care of as well.
So far from what I've read I have worn bushings to replace.
The Jester
Discussion Starter #2
Seriously nothing?
So far I've compiled
Inner and outer tie rods
Bump stops
Sway bar bushings?
Does the steering rack ever NEED to be replaced? Haven't found a suggested time on this.
What kind of sounds and symptoms are there? The way you explain it is way to vague. I mean it could be blown shocks or bad motor mounts. Try to get a little more detailed.
1 - 4 of 4 Posts
