1 - 4 of 4 Posts
I have 19x7.5 wheels with 45mm offset, I'm using 235/35 tires, I'm about to lower the car but it seems like the tire will rub on the lip in the rear well wheel, has anyone running this offset has had rubbing problems?
I'm lowering using a prokit, I know is not that low, but I'm concerned the most when the vehicle is loaded, i.e. three people in the back or two people and some luggage. This is in a sedan not a coupe, I don’t know if there are any differences in clearances between them.
Art M.
From what I have read in the sticky about rims you should be fine. Don't quote me because I am not sure if it was meant strickly for the coupe.
I think that the size of your tires are too big if you do a radical drop. if you do rub then you can roll the fenders.
1 - 4 of 4 Posts
