Description: The Power Slot Plus system uses a larger diameter, premium quality Power Slot brake rotor combined with your original factory brake calipers. The caliper relocation brackets space the factory caliper further away from the hub to accommodate our oversized brake rotor. This increases brake torque force without affecting pedal effort or travel. The larger rotor is also a more effective heat sink, absorbing the heat generated under heavy braking. This greatly reduces brake fade and provides consistently shorter stopping distances, especially from higher speeds.
