1 - 8 of 8 Posts
Bai Se Feng Che
How were they mounted in the headlights? Are you talking about verticle or horizontal alignment? All I know is that our headlight can only be adjusted up or down.
i<3 my P.O.S.
if i am not wrong there should be a hole on the metal frame on top of your headlight when you look into it with a flashlight you should see a gear with teeth u can use a flathead to turn it to adjust your headlight
registered n00b
he's talking about projectors though, not the OEM reflectors.
adjustability would be specific to your housing. it is a retro, or a aftermarket unit? if the latter, post the make/model of it, and maybe someone here with the same light can point u in the right direction.
1 - 8 of 8 Posts
