1 - 11 of 11 Posts
Hello everyone, im debating if i should get some 18" Volk TE37's 18x7.5 or 18x8? and if i get 18x7.5 or 8 would i be able to run 225 or 235 tires?
u can run those tires on either size. depends on what u want....if u want x8...u can if u want to fit a bigger size..liek 245...255..and so on....but if that doesnt matter to u...then just get the 7.5 and u can put the 235 on it....7.5 should be cheaper too.
itzjonjon69 said:
if i get 7.5 will there be a lip?
I run a 235 tire on a 7.5 rim. Fits perfect.
The lip all depends on the wheels, call whoever your going to be ordering the wheels from and theyll let you know what kind of lip you get with those wheels.
Tire size like 03accord said you can run either the 225 or the 235
hmm if i do get 18x7.5 could i run 245's in the rear? could i with 18x8.5's? or should i just stick with 18x7.5 and and 225's in the front and 235's in the rear or just go 235 all around
:and1: 18x7.5 with 235s all around. Will look perfect.
Edit: Unless you do a rear wheel drive conversion, then put some big fatties on the back! :cool: :p
has anyone bought these rims yet??? the te37's?? i'd love to buy these but want to see how they look on a silver coupe! or the le37t's.
phresh out the box!
235 with 18x8 should be fine. i actually have staggered wheels where my rear is 18x8 and the fronts are 18x7.5.
1 - 11 of 11 Posts
