1 - 2 of 2 Posts
Discussion Starter · #1 ·
Okay, well I decided to get some mods. Some 6.5Fr/6.9Rr speakers and Alpine Amp. Also, I want to upgrade my brakes since mines are going out. I'm thinking Brembo Blanks w/ Hawk Pads.
My questions are:
1. Are the speaker size correct?
2. The amp uses my car battery, is there anyway I can install another back up battery that I can hook my amp up to instead of my car batt?
3. Are these the rotors I need? Brembo Front & Brembo Rear
4. Will the rear Brembo Blanks fit my car? I have an 03AV6 auto.
registered n00b
(1) yes. however you may need a 1/2" spacer for the front speakers, depending on the mounting depth. the problem is that if the magnet is too big, it will bump into the window behind it.
(2) there are ways of installing a second battery, though you have to worry about installation, and increased load on the alternator. it is generally not recommended to add another battery without also upgrading your alternator. another option though, is to get an Optima Yellow Top battery, which is intended as a deep-cycle battery. you can run your audio equipment for a while with the car off, and sitll ahve enough cranking amps to get your car started again.
(3) & (4) cant help you there, sorry
1 - 2 of 2 Posts
