1 - 20 of 28 Posts
J35 6Spd
FS: A pair of CCFL halos
great for retrofitting... these are 95mm halos (95mm outer diameter), and should fit any 2.5" lens projector nicely. these are CCFL, not LED.. and will light up bright white. They are from Lite-eyes.com.. and carry a lifetime warranty against burning out if installed properly. Never installed.. comes with the voltage regulator unit and all wiring, including a toggle switch if you want to toggle them on and off.
Halos are in perfect condition. Paid 60, asking 35 shipped and paypal included.
Prices are firm.
Check lite-eyes.com for any other info needed
J35 6Spd
not a dumb question
theres no real mounting holes or screws on them... I'd say some high temp epoxy would be best. the CCFL tube is contained within a plastic ring that has a silver reflector on the back. the reflector part is flat allowing a lot of surface contact for epoxying on.
J35 6Spd
Discussion Starter #14
would they fit around the the 8th gen coupe projector?..if so i know someone that might be interested in these.
they fit perfectly to a 2.5" lens i believe... if someone can chime in with the size of the accord projector, that'd answer your question
1 - 20 of 28 Posts
