engine: j30a4 6mt cm8 chassis
anyone ever had issues with a rocker arm being stuck in place? i have a 3500 limiter and code p2649, solenoid has been replaced, filter is clean and not clogged, wiring to solenoid has been looked at by a specialist and it is fine, oil has been checked everyday since it started and is always the right level, even replaced it last night, is it even possible for a rocker arm to be stuck closed? note: the car starts normal no limp mode, as soon as power goes to the wheels the TCS and warning light comes on and it gives me a 3500 rpm limiter, it doesn’t misfire , it literally sounds like it’s hitting redline
