So I get the alignment done... besides the freaking | \ issue one other thing came up.
The car pulls hard to the right, to keep it straight I need to have the wheel at 1150 or so. Everything was fine before the alignment.
The sheet they gave me says everything's, 'cept rear camber, is kosher. Tire pressure is the same on both sides. Tried switching tires to diff sides, same pull to the right so this rules out radial tire pull.
Any other suggestions?
I AM LOST....
there was a TSB (i think) in FAQ that deals with car pulling to the right even after alignment many times.. check there..
