1 - 20 of 30 Posts
I just got an '07 EX-L V6 SEDAN. It is replacing a '99 of the same model. The '99 came with 15s and I put on 17s with 215/50/17 tires (exactly the size the car comes stock with now). After putting on the wheels/tires, I installed a pro-kit to close the gap. The car handled weird after that probably because the stock shocks/struts were compressed more than they were designed to be. I replaced the shocks with KYBs and it handled great.
I want to buy wheels and tires for the '07 and install pro-kit springs to lower the car a bit...but...I can't find ANY aftermarket shocks/struts for this car. Has anyone installed shocks on this car? Are the stock shocks ok after lowering the car? Anyone install aftermarket shocks? Will any shocks for 03-05 work fine on this car? I think most people are modding the coupe and I have a sedan. Thanks for any input or advice.
By the way, thank you DREW wherever you are for your invaluable info about wheel and tire setups. Any advice here? You have/had a sedan! Nice car.
Discussion Starter #3 (Edited)
I would be willing to pay to have the car handle well. I don't think there is a coilover kit for that car. Are there generic ones that would fit? Do most people just keep the stock ones?
Hfp
I found threads of sedan people using the HFP kit on the sedan. That was fitting the 03-05 kit.
From what Ive read, the suspension on coupe and sedan is identical, its just hard to access to replace the rears.
There are also a bunch of people in the sedan pictures threads with lowered cars. Perhaps read what their setups are?
oSCaR
are you kidding me? dude, every single kit that fits the coupe fits the sedan too without a single modification, coupes/sedans use the same exact springs/shocks... not to mention the TSX kits which also fit our cars and the TL ones fit too but there are PLENTY to choose from within the Accord Coupe category...
Thanks for the info. I didn't know that. It's not that I don't believe you, it just seems strange that not a single website tells you that. I inquired at Shockwarehouse.com and they replied with "Sorry, none of the shock companies we have offer units yet for the 2007 Accords". I don't get it. They are lame.
I checked through all the 7th gen photos and there are only a few accord sedans and most don't say what aftermarket shocks they have...if any. I don't think I really need/want coilovers as I doubt I am going to want to play around and adjust them all the time. I just want the car to look cool and handle decent with no maintenance on the suspension. As I said before, I'll probably go with an Eibach pro-kit for the springs. Anyone have suggestions for shocks? Keep the stock ones? I'm leaning toward just getting the KYB GR2s or maybe Koni yellows.
DIY Mania
As far as I know, GR2 is rated OEM replacement, meaning it's about as firm as the stock ones. Installing them won't really help with your bounciness issue.
I recommend a set of Koni Sport or Koni SP3 (from Neuspeed). TSX, 04-08 TL and 03-07 Accord share the same Koni shocks.
Where are you located?
oSCaR
There are plenty of sedans out there that have springs, shocks, and coilover setups from the coupes man. Trust me they fit, its been done over and over. The store you talked to just isnt updating their fitment guide, just like the AEM V2 intake wasnt listed to fit my 2005 sedan... but it fit like a charm... I think its still not listed to fit my sedan but even guys with 2007 sedans have the AEM V2 on their coupes/sedans! some of those guys also have the same coilover setups the 2003 guys used way back then.
TEIN Basic cheaper but good
TEIN SS-P little more expensive but great
TEIN FLEX(TSX) The most expensive but the best
yeah all those coilovers would be good, theres also the Tein Comfort Sport which is said to be the softest ride... one guy with a SEDAN V6 put those on his car, he sold his set to a guy with a coupe.
Besides Tein, theres also H&R, Buddy Club, D2, Tanabe, Ground Control, Omni Power is said to be out, and theres a few more also...
As the guys said, I would suggest going with TEIN for the better blend in handling and ride comfort. Get the FLEX for a sportier ride and handling. Or CS for a softer European car-like ride. I personally have the FLEX and I'm very picky about the ride comfort of aftermarket shocks and I think they ride better than stock. Harsher, but not bouncy, so it's much better than stock.
Discussion Starter #13
THANK YOU very much for the info. I really appreciate people taking the time to offer their .02. I've been out of the loop for a while since I bought everything for my older accord so long ago.
I'm glad you mentioned the AEM V2 because I have the non-V2 AEM cold air kit on my '99 and I didn't know the 2005 would fit the '07. It makes sense that it would fit but I thought maybe they moved the battery around or something. I know this is a question for another forum but does anyone know if you have to get creative to get the '05 V2 installed on an '07 sedan or is it exactly the same as the '05? I never dreamed the manufacturers are so lazy they don't update their fitment info...for two years!
I need to do some homework on coilovers. If I went with the TEIN SS, I guess I want the ones with the pillow ball upper mount? Not sure I understand the difference but the pillow ball mount allow the shock to be at a better angle and allows adjustment for alignment...is that correct?
DIY Mania
The pillow ball mount doesn't adjust alignment in our case, because it's not MacPherson strut suspension design. The pillow ball's main benefit is sharper steering feel because it's a solid piece of metal whereas the stock top hats have rubber bushings.
The downsides of the metal pillow balls are noisier and harsher feel because the vibrations the stock rubber bushings absorb, now are being transfered to the car and you.
IMO, it really depends on your tolerances of ride quality. If you want the car to retain the stock ride quality as much as possible, the coilovers are not for you. The spring rates on these Tein coilovers (except CS), especially Flex, are quite high and will stiffen your car considerably. The Tein CS should ride pretty comfortably, but they are designed for 4-cyl, not V6.
Discussion Starter #16
I think that coilovers are probably overkill for what I need, but I'm pretty sure the car will be bouncy with aftermarket springs and the stock dampers. The only adjustable shocks I can find for my car are the Koni yellows and they are expensive. Four Koni Yellow and an Eibach pro-kit is almost as much as a TEIN SS kit so I'm leaning toward the TEIN SS WITHOUT pillow ball upper mount. A shop told me you don't really need the pillow ball mount unless you plan to drop the car a lot...and if it is a harsher ride...I'll probably stick with the stock bushings on top. I'd like to lower the car around 1.5-2.0" front and rear. Will the TEIN CS (designed for 4cyl) work on my car or not?
DIY Mania
The Tein SS without pillow ball mount at its softest damper setting will still be firmer than Eibach Prokit and Koni Sport. However, if you want to lower it up to 2", coilover is definitely the way to go.
The Tein CS will work for your car, but it's even more expensive than SS-P.
Discussion Starter #18 (Edited)
Hey Champ,
What do you know about the shop in Chino Hills called "DirectTuning"? They seem to be a little more expensive than some others shops and I'm just wondering if that is a good shop with knowledgeable people. Thanks.
Thanks again for the feeback. I think the softer ride of the pro-kit and Konis is really what I am looking for. The 1.0-1.5 inch drop of the pro-kit would be enough for me. I don't need to be able to go lower than that. Also, I don't want to rub or bottom out in the back with people in the back seat. I found the Konis for $138 each and the pro-kit is a little over $200 so that is definitely less than what a Tein setup would cost.
DIY Mania
I only know their location. I haven't had any experience with them.
If you need help with installation, PM me. I have done suspension install on good 20 Accord/TSX/TL in the last year ranging from HFP, A-spec, springs/shocks swap to full coilover.
im sure this has been answered before. but i have a 2006 sedan 6mt. i can get an hfp kit pretty cheap, was wondering if 100% sure it fits the sedan and will hold out. and if so, how much better is the hfp kit? will i really notice the difference or do i need to go aftermarket? i have a comptech rear swatbar already if that makes any difference
1 - 20 of 30 Posts
