i think u need a better tune.... its running pretty rich
Rich? I'm seeing "lean"... in "boost" with "load" I'm thinking between 11.5 -12.0 f/a is a good mark to stay in.reccakun08 said:i think u need a better tune.... its running pretty rich
hmmmmmmmm i was told my car was hitting 14:1 a/f ratio up top so he had to add more fuel via the FPR. I did notice that my car felt a little quicker and i verifed that when i made an 85-115mph run against my brothers camaro SS. Even though he won, he took me by a little more than a car length. Before the tune he would win an easy 2 car lengths and still be pulling. half the reason i lose is because his auto shifts down to second and im stuck in 3rd gear.Lumpy said:The higher the #, the leaner the a/f. For example 13:1 is leaner then 11:1..You should run the highest octane available for your car and then you need to lean it out about another 1/2 turn. The higher octane will help to keep you from detonating up by redline and the 1/2 turn will bring your a/f up in the mid range. Your a/f has way to much variation. Look at Blackv62k2 graph. Hes getting max power in the 12.5 range. Last time I dynoed my car, the a/f (measured at the tailpipe) started at 11.8 and went to 12.6 at redline. Ideally, you would keep your a/f from ever dipping down below the 11.0 marker.
Trying to keep the mids in 11s will lean out the already lean top-end. This is of course with just FPR tuning. I know this can be done with Emanage. I would like my mid to lean out some more but I don't wanna risk leaning out the top.Lumpy said:The higher the #, the leaner the a/f. For example 13:1 is leaner then 11:1..You should run the highest octane available for your car and then you need to lean it out about another 1/2 turn. The higher octane will help to keep you from detonating up by redline and the 1/2 turn will bring your a/f up in the mid range. Your a/f has way to much variation. Look at Blackv62k2 graph. Hes getting max power in the 12.5 range. Last time I dynoed my car, the a/f (measured at the tailpipe) started at 11.8 and went to 12.6 at redline. Ideally, you would keep your a/f from ever dipping down below the 11.0 marker.
Ha! Hence the a/f (air to fuel) ratio. I stand corrected and stupid!Lumpy said:The higher the #, the leaner the a/f. For example 13:1 is leaner then 11:1..You should run the highest octane available for your car and then you need to lean it out about another 1/2 turn. The higher octane will help to keep you from detonating up by redline and the 1/2 turn will bring your a/f up in the mid range. Your a/f has way to much variation. Look at Blackv62k2 graph. Hes getting max power in the 12.5 range. Last time I dynoed my car, the a/f (measured at the tailpipe) started at 11.8 and went to 12.6 at redline. Ideally, you would keep your a/f from ever dipping down below the 11.0 marker.
That's the problem with us SC guys tuning just with the FPR. We're lean down low and up high but quite rich in the mids.reccakun08 said:What? you dont make any sense.
Anyways his car is def running rich after ~3.5 and pretty lean before 3. For boosted cars you want to stay around ~11.5-12ish. With a better tune u can definately squeeze more power and have better gas mileage.
Yeah, tuning by those methods tune the whole powerband which is to say that if your low end is rich and your bogging you will lean it out but lean out the high end as well, and vis versa possibly. Thats why a piggy back ECU is great for tuning.BlackV62K2 said:That's the problem with us SC guys tuning just with the FPR. We're lean down low and up high but quite rich in the mids.
you cant get a much better tune with just the FPR. like other have said it tunes the whole powerband so if u lean the mid section out, your top end would be extremely lean.reccakun08 said:What? you dont make any sense.
never ran itRed02AccordV6_2 said:just wondering, how fast do you run in the 1/4?
i think the safc is outdated. Unichip tuning in norcal is garbage. That pretty much leaves just greddy e-manage and i dont know of a good shop that will give me a decent tune. Ive spend more than 3 times the money that I should have spent just to get a decent tune. Thats why i am so wary of purchasing a chip. It would defeat the whole purpose if the shop can't do their part and will just leave me dissappointed.reccakun08 said:why not get safc or something? i know standalones are expensive b/c im sure u would have gone that route. but definately some sort of safc. do u have a wideband?
I think they should be sufficeient for the cls pulley. the only time the the oem injectors have trouble supplying fuel is the very top end.reccakun08 said:270cc injectors i think is still a bit small for the power you are running
