1 - 6 of 6 Posts
I am trying to do a speaker level input for my amp from right before my rear deck speakers. Does anyone know, looking at the stock speaker wire, which color is plus and which is minus? Please let me know. Thanks.
registered n00b
sorry in advance for not having a direct answer.
but heres how u can find out on ANY car or on ANY speaker: just unplug the wires (but remember which went where). take a battery, and some scrap wire if you so desire, and rig up each terminal to a different terminal on the speaker. if the cone moves OUT, then the polarity is correct (ie. the end that you hooked up the + of the battery to should be the positive end). if the cone moves IN, then you got it backwards.
Anyone with the service manual know for sure the colors?
Thanks for the post Wong.
2003 Honda Accord
Code:
FUNCTION .... WIRE COLOR .... POLARITY .... LOCATION
12volts .... white .... + .... ignition harness
Starter .... black/white .... + .... ignition harness
Ignition .... black/yellow .... + .... ignition harness
Accessory .... black/red .... + .... ignition harness
Second Accessory .... white/red .... + .... ignition harness
Keysense .... red/white or red/black .... - .... ignition harness
Power Lock .... pink/black .... - .... grn plug, L side of fusebox
Power Unlock .... pink/blue .... - .... grn plug, L side of fusebox
**These wires will meter while using the passenger door lock switch.
Lock Motor .... yellow/black .... 5wi .... grn plug, front of fusebox
Unlock Motor .... yellow/green .... 5wi .... grn plug, front of fusebox
Disarm Defeat .... yellow .... 5wi .... large wht plug above fusebox
Parking Lights+ .... red/black .... + .... large wht plug above fusebox
Parking Lights- .... black/red or blue/red .... - .... in steering column cover
Hazards .... green/red .... + .... large wht plug above fusebox
Turn Signal(L) .... red/blue .... + .... large wht plug above fusebox
Turn Signal(R) .... brown .... + .... large wht plug above fusebox
Door Trigger .... green/red .... - .... grn 5 pin plug behind fusebox
Trunk/Hatch Pin .... blue/black .... - .... driver kick, harness to rear
Hood Pin .... yellow/red .... - .... hood pin switch in latch
Trunk/Hatch Release .... yellow/green .... + ..... driver kick, harness to rear
Factory Alarm Arm .... white/red .... - .... driver door module in door
Factory Alarm Disarm .... white .... - .... driver door module in door
Disarm No Unlock factory alarm disarm
Tachometer .... blue/red or blue .... AC .... ECM/PCM
**The ECM/PCM is on the front of the transmission tunnel.
**The connectors are on the passenger side.
**On the 4 cylinder models the tach wire is in the white 31 pin connector E, pin 25.
**On the 6 cylinder models it is in the gray connector A, pin 23.
Horn Trigger .... green/yellow .... - .... steering column
Speed Sense .... blue/white .... ECM/PCM
**On the 4 cylinder models the VSS wire is in the white 31 pin connector E, pin 26.
**On the 6 cylinder models it is in the gray connector A, pin 11
Wipers .... blue (L), yellow (H) .... - .... windshield wiper motor
LF Window up/dn .... red/black - red/yellow .... LF window switch in door
RF Window up/dn .... red/blue - red .... RF window switch in door
LR Window up/dn .... red/white - blue/black .... LR window switch in door
RR Window up/dn .... red/white - blue/black .... RR window switch in door
Sun Roof open/close .... green/yellow - green/black .... moonroof motor, rear of roof
**Only on the sedans.
**Coupes: the moonroof motor is integrated into the moonroof control unit not allowing
**access to the motor wires.
Radio 12v .... white/green .... + .... radio harness
Radio Ground .... black .... - .... radio harness
Radio Ignition .... yellow/red + .... radio harness
Radio Illumination .... red/black .... + .... radio harness
Power Antenna .... yellow/green .... + .... radio harness
LF Speaker +/- .... green/black - lt. green .... radio harness
RF Speaker +/- .... grn/yel - gray or gray/red .... radio harness
LR Speaker +/- .... blue/white - blue/black .... radio harness
RR Speaker +/- .... pink - blue/yellow .... radio harness
1 - 6 of 6 Posts
