1 - 16 of 16 Posts
Hey guys, it's about that time to consider an exhaust system especially with tax returns in a week or so. I just wanted some suggestions to help me out. So far I have a 05 AV6-6 with I/PCD/ Xlr8Jpipe. I want to car to be as quiet as possible which means I plan on leaving the Cat. converter intact or upgrading to a high-performance one plus a resonator. The car is still very quiet unless I'm in Vtec. Also, I have the 06 rear lip as well as I have seen people have had fitment issues fitting their muffler tips through the rear lip. Any suggestions on diameter size, type of muffler, piping, resonator? I live in Miami as well so I have no issues with emissions, just thought I'd mention that.
SSM_AV6-6
For a full catback, the Borla seems to be the quietest one available. I am in the same exact boat. I am doing HFPC and the XLR8 J-pipe, but am undecided as to what I want to do with the rest of the exhaust. I want something ideally OEM, like an LS430 axleback, meant for more power and as quiet as OEM accord exhaust. I would like a 2.5" midpipe with a long resonator. But if I can find a Borla for cheap enough I may just spring for that. It looks a lot like stock, and isn't very loud at all.
What diameter are you guys thinking on the midpipe before the Y. I think I read online that someone had 3" but I'm not sure if they were doing single muffler. I want double mufflers and I was thinking of just getting the mufflers and have the shop custom the midpipe and put on the exhaust for me as well. I was actually leaning towards full custom with a good resonator, but I don't know if the car will be quiet still.
SSM_AV6-6
Sonnick mentioned he had the 3" single exhaust, and I think he had a resonator and said it was still too damn loud. Which discourages me because my original plan was to custom make an entire exhaust like what you want, using a Magnaflow resonator and probably Flowmaster mufflers.
ER MER GERD!!!!
Apex'i WS-II is nice and quiet even w/ the XLR8 V2 Jpipe. under normal cruising almost as quiet as stock.
Just leave the stock catback and put in an electric dump passed the Jpipe. Wisper quiet when ya need it, screamin when ya want it;). Prolly perform better then a catback anywyas.
This.
Or you can do a 3" midpipe with an ever larger resonator than I currently have (6" round X 30"). You could do the Magnaflow 5x8x24, which has a good amount more volume than mine. You may only need small mufflers with that reso.
But if having a quiet exhaust is priority, go with a 2.5" midpipe. You can still use a large resonator (5x8x18 or so) and 2 nice mufflers. I'd suggest Magnaflow (5x8x14) or Vibrant Streetpower (5x9x15). The Vibrants should be a little quieter given their larger size. Either should sound very nice and still maintain quiet exhaust note you're looking for ;) Keep in mind that anything smaller than suggested will probably be louder than you want.
Discussion Starter #9
This.
What would the diameter of the Y be when the mid-pipe fuses into the two Left/Right pipes to the mufflers, still 2.5"?
The muffler shop will know what to do. At the end of the midpipe where the Y split is they should have 2 2.25" pipes meeting to form the "Y." So in essence, the mufflers you buy should have a 2.25" inlet if you go with a 2.5" midpipe. If you go with a 3" midpipe, you should buy mufflers with a 2.5" inlet.
You could always buy a Y pipe btw. A lot of companies shelf them.
SSM_AV6-6
Ironically, the 3" seems quieter, as long as a nice resonator and large mufflers are used. I went with a custom built 3" catback with Magnaflow resonator and two 2.5" Magnaflow muffers. Pieced together, including having a shop do the welding/mounting, you should be spending roughly $450 for that setup. It sounds like the consensus is light mods = stick with 2.5", serious mods (entire exhaust upgrades, good intake at least) = 3".
Discussion Starter #15
Well, I have PCD and j pipe as well as intake so I guess I will be doing pretty much what you did with the 3" mid to 2.5" y pipe to mufflers.
I don't want to buy Borla because they are expensive and I hear they are equal or lesser performance than going the custom route.
SSM_AV6-6
Well, for a mass produced catback I would say Borla is my all-around favorite. However, with performance a high priority, it couldn't hurt to custom make a 3" exhaust. If I was happy with just an intake and catback, I'd definitely get the Borla, but with HFPC and JP on the way I would hate to spend more money for less power lol.
1 - 16 of 16 Posts
