1 - 2 of 2 Posts
Finally trying to installing my rear sway and have some questions for anyone who has intalled one.
The first question is did you have to drill the mounting hole in your trailing arm? Im pretty sure you have to drill the hole because the drake line bracket is in the way.
Also did you have to increase the length of the endlink like in this http://www.accordinglydone.com/forum/showthread.php?t=8053&highlight=rear+sway thread? The difference in the two cars in this thread is that one is a LX and the other is a EX and the EX is the only one to come with a rear sway .....according to Madified Mag.
The ST rear sway is 21mm in diameter and the stock on is 15mm This will be a def. improvement.
Currently i have stopped the installation because it started to rain as soon as I got the first bolt off.:angry:
Discussion Starter #2
Never mind i have found my answer and will post pictures or a video tomorrow and give a indepth review. :up:
-B-
1 - 2 of 2 Posts
