Koni Yellow Shocks & Ground Control Coilovers.
I just recently put air struts on my car and might be selling my old suspension setup. Koni yellow adjustable shocks with ground control coilovers. These koni shocks are the ones made to be used with the ground control coilovers. Both in good condition. Some scratches on the shocks and a few rub marks on two of the sleeves for the coilovers. When the setup was first put on the car they upper rubber was put on wrong causing the spring to rub the sleeve. Does not effect anything just some of the upper sleeve threads are shaved down a little bit but you never adjust them that high unless you are going for the 4x4 look.
The ride was great with this setup.
