1 - 20 of 227 Posts
THLA 2009 Bombsquad
Hello fellow V6performance Admin, Mods and Members.
With all the new threads lately with people asking about wheel offset fitments on their cars I am going to make an official 6th gen wheel offset thread.
This thread will help fellow members decide on what wheel setup will look good on their cars.
I will update this thread when I am updated with the wheel size, , tire size, wheel offset, and camber adjustments.
This is strictly for 98-02 Accord Coupes and Sedans only.
I am assuming that this thread will work by members giving me information on their wheel and suspension setups and I will post up pictures of the setup for other members to look at.
So until further updates I will start this out with my wheel and suspension setup.
We can follow this guideline [subject to change if other members give me more info]
1999 Honda Accord V6 Coupe
Work Rezax Staggered Wheels
Front: 17x7 +38 Offset
Rear: 17x8 +38 Offset
Tire Size: 215/50/17 Front + Rear
Fenders Rolled: Rear
Suspension: Skunk 2 Coilovers + Tokico Illumina Shocks
Lowered Amount: ~2.5 Inches
Camber Adjustment: No Camber Kit Installed [also no alignment since recent suspension adjustment so this setup will look different when I put my wheels back on in the spring and get my camber kit installed and get an alignment]
Happy wheel hunting and I hope this thread will help other members out
So let's get this thread start up =]
2001 Honda Accord EX i4
SSR Formula Mesh
Front: 17x7.5 +19
Rear: 17x9 +39
Tire Size: 205/40/17 Front 215/40/17 Rear
Fenders lips flattened, no rolling or pulling yet.
Suspension: Ksport Full Coilovers 13k/7k
Lowered Amount: Around 2 Inches
Camber Adjustment: Hell if i know, hahahaha. I plan on getting a camber kit this spring, front and rear and go ALOT lower.
The End.
Wheels: RAYS Foundry Arthur Exchange (A/X) MM-X
Front Specifications: 18x7.5 +42 Offset
Rear Specifications: 18x7.5 +42 Offset (+27 after 15mm spacer)
Tire Size - Front&Rear: 225/40/18
Fenders Rolled/Cut: Rear
Suspension: Function Form Type II (older version)
Lowered Amount: 3.3±.1 Inches
Camber Adjustment: Front: -1.3, Rear: -1.3
Notes: Will rub just a tad. Might need to adjust camber to -1.5+ for the rear, IF you decide to run with a 15mm or +27 offsets. Stretching tires will work as well.
(With rear spacer; )
Super IcyAccord
1999 Honda Accord V6 Coupe Vtak Edition
Mazda Rx8 Wheels
Front: 18x8 +50ET
Rear: 18x8 +50ET
Tire Size: 225/40/18 F & 225/45/18 R
Fenders Rolled: None
Suspension: D2 Coilovers
Lowered Amount: enough? lol i dunno really.
Camber Adjustment: Camber kits are worthless. -2* front, and -3* rear :)
Destroyer of Tires
Dang if everyone is going to reserve a spot than I should too.
Hopefully soon I'll be posting up some new specs.
EDIT:
2001 Honda Accord V6 Coupe
Gram Light T57-RC wheels
Front: 18x7.5 +48mm Offset
Rear: 18x7.5 +48mm Offset
Suspension: Tein SS coilovers with one spring seat removed from the front two coilovers
Lowered Amount: ~3.3" Front, ~2.5" rear
Camber Adjustment: No Camber Kit, but my guess is that my camber is around -2.5 degrees.
k24/k20 Turbo coming soon
2001 Honda Accord LX i4
SSR Professor SP1 Black w/Anodized Lip
Front: 19x8.0 44mm offset = 5mm H&R Spacers
Rear: 19x8.0 49mm offset
Tire Size: 225/35/19 all around
Fenders lips: not rolled
Suspension: Apexi WS Coilovers
Lowered Amount: about 2.5-3.0 Inches all around
Camber Adjustment: No camber kit and I don't get bad tire wear, never have since lowered in 02 :D
Brad
1998 Honda Accord I4 LX coupe
Wheels: Work Varianza T1S, gloss black face
Front: 19x8.5, +45 offset
Rear: 19x9, +38 offset
Tires: Falken ST115 225/35/19s front/rear
Fenders Rolled: front/rear
Suspension: APEXi WS coilovers
Lowered Amount: ?? (I'll update this once I determine an exact amount)
Camber Adjustment: Ingalls camber kits front/rear (not sure of exact camber measurements)
same avatar since 03'
2000 Honda Accord V6 Sedan
Advan AVS VS-6
Front: 17x7 +30 Offset
Rear: 17x8 +35 Offset
Tire Size: 215/45/17 Front + Rear
Fenders Rolled: Front + Rear
Suspension: Ksport Control Pro Coilovers
Lowered Amount: 3.5 to 4 Inches
Camber Adjustment: -3 all around
v not some model, my girl
1999 Honda Accord V6 Sedan
Ron Jon Luxury Sport Design Legend type II
Front: 20x8.5 +52 Offset
Rear: 20x8.5 +52 Offset
Tire Size: 225/35/20 Front + Rear
Suspension: Air Ride
Lowered Amount: As much as i can
Camber Adjustment: None
ill get some better pics tomorrow
Back in the day
Rim: Motegi DP10 17x7 front and rear
Tire: 215/45R17
offset: 42
and a change for 2009
Rim: ASA JH8 18x8.5 front and rear bout 19lbs per wheel
tire: 225/45R18
2001 accord v6 coupe
Enkei Evo 5's Wheels
Front and Rear: 18x7.5 +45 Offset
Tire Size: 225/40/18 Front + Rear
Fenders Rolled: No
Suspension: Eibach Sportline + Tokico Illumina Shocks
Lowered Amount: 2 Inches
Camber Adjustment: Ingalls Rear Camber Kit
02 i4 Sedan
RH C-3
17x7 +40
215/45
Need to roll the fenders
Ground Control & Illumina
Never measured before i dropped her, pretty low though
3 deg camber back 1 deg in front
2001 4Cyl 4Dr
RH Evo C2 18x7.5 +42et
215/40 up front; 225/40 rears
Apexi WS Coilovers dropped around 2.0" all around
gotta dig up my camber specs
The End.
Wheels: Advan RGII
Front Specifications: 18x9 +22 Offset (GTR face)
Rear Specifications: 18x10 +25 Offset (GTR face)
Tire Size/Model - Front&Rear: 225/40/18 Dunlop dz101
Fenders Rolled/Cut/Pulled: Front and rear rolled&pulled ~3mm
Suspension: AMR
Lowered Amount: a lot?
Camber Adjustment: Front: -2.2, Rear: -4.0
Notes: I had my doubts, but it's possible. Rubbing is minimal, or so I shall see.. during canyon cruise. Extremely difficult to pull off. GOOD luck.. probably better to go with 9.5 to save some headaches and $.
*VIP ACCORD*
2002 Honda Accord EX V6 Coupe
Wheels: Work Equips DDC 3pc. Forged Aluminum
Front Specs: 17x8.5 +40 Offset & H&R 15mm spacers (+25)
Rear Specs: 17x9.5 +40 Offset & H&R 15mm spacers (+25)
Tire Size/Model: F= 205/45/17 R= 215/45/17 Falken Ziex ZE-512
Suspension: Koni Yellows & Ground Control sleeves w/ custom spring rates (8K/6K)
Camber Adjustment: Front: -2.0 Rear: -3.0 (Ingalls front & rear)
Lowered Amount: Dumpage!
Notes: Only Equips in this look...
Pictures: Coming Soon...
Euro accord wannabe
1999 Accord ex-l V6
Wheels: 2009 OEM Honda Accord coupe
Front: 18x8 + 55 offset
Rear: 18x8, +55 offset
Tires: Kumho Ecsta ASX
Fenders Rolled: nope!
Suspension: Tein SS
Lowered Amount: 2-2.5 (too much for daily driving in Vancouver)
Camber Adjustment: psh camber ftw!
1 - 20 of 227 Posts
