ok for everyone out there that has either performed the j32 +6spd either with me or anyone else....here's a fix that you might want to pay attention to.....
first secret...to make the reverse light work on the v6 accord...you have to swap the pin onf the cabin harness side of the engine harness( found drivers side of the of the vehicle.) after this swap...it should put the blue black wire in the position of the reverse lock out colenoid.....then cut the wire...from the fuse box connector(again drivers side)...solder another wire from there over to the ecu....on teh cl-s ecu it's pin E15.....other wise....you may destroy reverse gear.....and after fix four of these problems for free.....I'd rather ;et everyone know than keep it secret......hahhhahahahaha but don't think there aren't more out there....I just don't want to see anyone brake thier stuff
Aidan
Aidan
