1 - 20 of 39 Posts
JDM UC1
nope. only problem i came across was when i dumped the front. shock was not low enough, so i was bottoming out. i was tucking tire in front then. raised to not bottoming out, rides good.
James
^^ does removing them give more low/ adversely affect the ride (noticeably)?
JDM UC1
Discussion Starter #15
yes. remember when you buy lowering springs and instructions say cut the stops in half? since i went lower and lower, i had to cut the stop more. w/o cutting the stops you'll end up laying the top hat on the stop and the ride will be uncomfortable.
1 - 20 of 39 Posts
