1 - 4 of 4 Posts
Discussion Starter · #1 ·
Hey,
Anyone know the torque spec. for the upper strut/lower strut/ball joint(?) bolts on the shocks. I remember seeing it on one of my searches but i can't find it anymore...
thanks
Torque for the nut on lower balljoint is in range of 36-43 lbs/ft
Torque for the nut on upper balljoint is in range of 29-35 lbs/ft
Torque for the nut on strut mounting base and strut’s shaft is 22 lbs/ft
Torque for there bigger nuts on strut mounting base and car’s body is 37 lbs/ft
Torque for two smaller nuts on strut mounting base and car’s body is 12 lbs/ft
Torque for the bolt and nut on lower control arm and strut’s fork is 47 lbs/ft
Torque for the bolt on strut’s body and strut’s fork is 32 lbs/ft
1 - 4 of 4 Posts
