TRUE CLS6 SWAP - 6th Gen Accord 2023
1563 Views 11 Replies 4 Participants Last post by  ThunderyZero930
8
it’s 2023. I have done millions of research regarding the 6th gen accord 6 speed swap. All the well written forums that currently exist are both extremely outdated and don’t usually contain a true swap (via the swap module, or using the non-LSD trans), perhaps just someone swapping a 6 speed into their 7th gen chassis, or god forbid those people to admitting they paid a shop to do it .
I will show photos of progress and keep updating as I go.. there is so much that people don’t mention. I won’t be adding a parts list because they’re literally everywhere but I will talk about each major swap component and what it took to get it to fit.. STAY TUNED !
Automotive parking light Tire Car Vehicle Wheel
1. Before the swap J30a1 stock engine with 4 speed automatic transmission.
Motor vehicle Hood Auto part Vehicle door Trunk
2. Acura CL-Type S shifter has 4 bolts, one you remove the auto shifter it WILL fit without any modification. Obviously before the assembly is bolted down you'll run both shift cables through the hole where the auto shifter once ran, leading to the top of the transmission versus the bottom.
Light Automotive tire Automotive exhaust Motor vehicle Automotive design
3. Next came the clutch pedal..(whew). In my CG1 there indeed were provisions for where the pedal/master cylinder should go. Space wasn’t very limited believe it or not, also with a good hammer drill and drill bits I made quick work of the firewall and also the hole above where the reinforcement goes. I also used 3/8 by 1/2inch spacers from Home Depot (about 5 bucks for 2) to rectify the strength. Just for your information clutch pedal / master cylinder combinations from ANY 90's will work but they have to match. For example, you can use 90-97 Accord clutch pedal/master cylinder together, or 98-02 style pedal/master cylinder. You cannot mix and match because the brackets for the pedals are different lengths and the master cylinder will appear to be way too long or way too short. The final product is not depicted, but instead of swapping the brake pedal assembly I instead trimmed the factory auto pedal to accommodate for the new spacing.
Wheel Tire Automotive tire Motor vehicle Tread
4. In my opinion, probably the most important component to the swap are the transmission mounts. Once you remove the 4 14mm nuts holding in the stock automatic transmission mounts (2 per mount), you will be able to sit these in place no problem, without modification. It is literally impossible to sit them in the wrong spot/orientation as the length between the studs are different and have slight different elevations that have similar curvature to the subframe. The reason why I feel these are the most important pieces is because right now there are no aftermarket options available for these mounts, and they are totally discontinued from Acura. In addition to that, you'll need these mounts to even SIT a CLS or 7th gen V6 transmission into your CG. I would recommend sourcing these first. Of course there is the transmission "beam" you use to connect these mounts to the transmission, but in this day and age we can go to P2R and grab a billet one for about 150 bucks.
Automotive tire Motor vehicle Automotive exterior Gas Automotive design
5. Of course, there is the transmission itself. Depicted is an Acura CL-S 6 speed with LSD (coded "C5") bolted to my J35a4, which I have modified to accept the standard components (I have a write up on how to do that also). The transmission will bolt up directly to any 1st generation style J series engine without modification, as they (obviously) share the same bell housing shape. Also, if you see closely I was able to use the stock 6th gen half shaft from the automatic transmission as well.
Car Vehicle Motor vehicle Automotive air manifold Automotive design
6. I WILL be changing this photo later to a cleaner one, but I am just trying to keep frequent updates. Once the engine and transmission are together, go ahead and purchase yourself some new 6th gen accord v6 chassis mounts and drop it in (your existing mounts will work but just for good measure). I found it more practical to get the motor to sit on the front and rear mounts, then install the passenger side, and finally, with the beam already on the transmission, INSTALL THE TWO TRANSMISSION MOUNTS LAST! The engine wiring harness itself fits perfectly into our chassis , I found it much easier to first send the 2 plug side into the firewall, and continue routing it from engine to the manual transmission side. The harness will totally fit every plug on the engine and transmission, there’s even two “giant” plugs that fit the stock accord ones on the body. For the shift linkage it should have been ran through the hole where the auto shift cable used to be and run to the top of the transmission, the manual shift cables fit perfectly into the bracket as intended, I had to remove some square damper thing located next to the rear mount and it was no problem .
Car Vehicle Motor vehicle Hood Automotive design
7. This is how she sits currently. It appears much taller in real life as I’m using the Honda Pilot intake manifold spacer and Taylor Helix throttle body spacer (now discontinued) . Despite the bolt-ons believe it or not, I didn’t have to modify the harness in any way for the plugs to reach. Now, as far as accessories, I was able to re-utilize the stock J30 power steering pump as both motors have similar provisions, same with the alternator (although its not in this picture). The throttle body used is the stock J30 one as well, which I preferred because one, (to my surprise) it was the same diameter as the opening to the J35 intake, secondly the plugs on it accommodated perfectly for the CLS harness. Important note, I would recommend running a new J30 PCV valve as it has an angle tilted upwards, the J35 one is 90 degrees and just doesn't fit (my set up) as well
Textile Sleeve Motor vehicle Bag Luggage and bags
8. Here I have integrated the CLS “E” plug with the Accord chassis “A” plug. Using the ProDemand software I was able to figure out which wires matched between the two different harnesses to get things like OBDII port, MIL, immobilizer light, cooling fans, AC compressor clutch, etc. to function properly. There’s a whole misconception about the radio, heat not working without this part but that’s entirely not true. Your radio , power seats and clock will work without this step, however integrating the harnesses gain you full functionality, and obviously the ease of diagnosing any problems you may have. There are conversion harnesses available to make the “A” clip integrate perfectly into the “E” port but you don’t need to spend that money. If done correctly there should be like 2 wires left on the “A” side and like 3 left on the “E” side, unless you choose to run wires all the way to the corresponding components.
WRITE UP CURRENTLY IN PROGRESS
See less See more
1 - 12 of 12 Posts
[/QUOTE]
definitely glad seeing a current build being done. Currently have a v6 6th Gen that’s been sitting and have the itch to convert To MT. Just gonna follow along to see what is needed especially considering the 6SPD tranny is easier to find/afford.
What harness/ecu combo are you using?
  • Like
Reactions: 1
Man i wish 🙃 this is my AT 99 Accord V6
Wheel Tire Car Vehicle Land vehicle
See less See more
  • Like
Reactions: 1
[/QUOTE]
Thanks for following the thread and I’ll be sure to cover it im using CLS 6 harness and ecu for simplicity.
Man i wish 🙃 this is my AT 99 Accord V6 View attachment 22075
She’s gorgeous ! Sedan gang lol
Dang, mine isn’t on coil packs tho. Wonder how I gotta work around that.
[/QUOTE]
[/QUOTE]
[/QUOTE]
[/QUOTE]
Just off the top of my head I’m sure you’ll need a year 2000 plus head without the provisions for the distributor, also an ecu from the same model (which I am now selling ;) ) because they contain the proper transistors (fancy way of saying ground control) to power the coils.
Finally.... someone is making my old rolling dumpster the worst example 😁 I knew someone would do it eventually. Dude, this is SWEET. My project was always intended to be just a cheap hack and something to keep my hands busy; I also felt challenged by people saying "can't do this, need some special magic box" or whatever. My goal was to see if I could swap in the manual transmission and see if I could trick the stock ecu into working (....see what I did there :ROFLMAO:) I always figured the flow chart for swapping any Honda works like this:
Is it a Honda: Yes/No
Yes = it is swappable
No = N/A
Be informed when getting suspension stuff for the 6th gen, I've found a lot of substandard junk out there and that stuff makes the ride quality terrible. As for that CLS lower beam transmission mount, did I read correctly in that you found an aftermarket solution?! If so, I am beside myself. I knew someone would find it... I lucked out and found a good used lower beam thingy on ebay. All the rest I went with Innovative, and those worked well for me, but I always wondered if there was something better out there. Still, the J ran like a dream on poly mounts, and I never encountered any vibration- in fact, at idle the steering wheel felt really nice.
Feel free to reference any of my old work, videos etc. maybe you can point out differences in approach, better choices for parts or for handling some little "gotcha". Cloning the key RFID for the donor key/ECU is pretty straightforward, pop out the little RFID pill thingy, tape it into your current key, have a key place clone THAT... now you have a key that fits your ignition and is read by your donor ECU.
I started hacking TL stuff onto the car, wheels, seats etc. but I did not like the fitment of the seats. I also never got around to wiring in the seat heaters prior to selling the car; pretty sure that needed the controller from the TL. I felt like the wheels worked out well for my swap, but they were free- dude had some cheap aluminum wheels ON the car and the TL rims were in the back seat and trunk.
Here's the link for the place where I got my electroluminescent gauge faces:
There may be better "local" options these days, but he did a fantastic job with my guages.
I'll be following this build, keep up the good work dude!
-John
See less See more
No = N/A
-John
You don’t remember me? I’m the guy who identified you BY NAME on your J35A1 write up when I noticed the things you put reminded me of your old YouTube content.. you even gave me your DropBox lol
Oh, I remember :love: just wasn't sure if I would see the build on here or not... there aren't many of these that I've seen, at least not with details like yours. I've genuinely been hoping someone would take on the challenge and build one that puts mine to shame- I set the bar pretty low.
I absolutely LOVE the cut brake pedal- it's a badge of honor for this swap... and anyone that's looked into swapping out the pedal assembly has likely felt the same hard NOPE as I did :LOL: Nice job on the clutch pedal install!
  • Like
Reactions: 1
Yeah man people are suggesting I swap it correctly and I’m like put yourself in my crocs and see what kind of decision YOU make lol .. installing that clutch pedal on its own was not a recommended experience .
1 - 12 of 12 Posts
