1 - 8 of 8 Posts
Would it be possible to use a tsx intake on the v6 accord. Sounds odd but the mugen, j's, group m, and ct all have the intake box in the same spot that the stock one was on the accord (sit's in between the battery and fuse box). the only modifying would be the tube connecting the air box and throttle body...so would this be possible to do? It would be sexy to have a cf mugen airbox. I know your thinks why spend 1000 on an intake, well lets just say I might be able to get a hook up on one and I want to know if it will work before I bite the bullet!
here is a picture of it: http://j-sracingusa.com/Accord CL7/accordcl7_intake.html
Here are links to compare the two stock are boxes...
accord:
http://www.v6performance.net/forums/7th-generation-honda-accord-2003-2007/192945-7th-gen-v6-engine-bay-pics-3.html
tsx:
Changing engine air filter - Acura TSX Club : Acura TSX Forum
Your mounting points would probably be different and your V6 battery is probably a bit bigger as well.
Why not buy it anyway if you're getting hooked up and sell it on TSX forum for profit?
DAT Dewd from Dallas MANG
mounting point for this box?
that's really all that matters is the mounting points...
you can always relocate the battery...:p
If that's the case he can also fabricate brackets to use the mounting points.
try to find someone with a TSX and see if you can take a look at their intake box and compare the two.
1 - 8 of 8 Posts
