here are the instructions.
these instructions are Do-It-Yourself! they may or may not woid your warranty! they may or may not **** up your car! you assume all risks if you try this mod! questions are welcome, complaints are not! thanks
In the 7th Gen fog switch there are 5 wires:
Red/Blk - Hot with Parks & Heads on / In for illumination
Red - Out for illumination control
Blue - Hot with Heads on only / In for switch
Green - Out from switch to Relay #2
Black - Ground wire
**only the Red/Blk & Blue wires are actually hot**
1) You don't need to remove the dash or anything! Simply use a small hook tool, & pull the outer trim on the 3 switch panel. the panel & all 3 switches with pop out together.
2) Unplug the 3 switches from their wiring harnesses. Put switches aside in a safe place.
3) Peel back black electrical tape / wiring cover to allow yourself more slack to work with. You can use scissors or a razor but be careful not to cut any wires!
4) Cut the blue wire, leaving at least 3 inches of slack on the plug end. Strip a small section of the plug end. Cover the firewall end with a small piece of electrical tape.
5) Splice into the Red/Black wire, but do not cut it!!!
6) Connect the plug end of the Blue wire to the spliced Red/Black wire. You can do this with butt connectors, soldering, or simply threading the wires together & capping them. It a personal preference, so do what you're comfortable with.
7) Double check all connections. Plug fog switch back in only & test! do not put back into dash.
8) If successful, wrap all connections in electrical tape. Plug all switches back in. Mount panel back into dash with slight pressure
9) Enjoy!!!
Black - Ground wire
9) Enjoy!!!
