i bought 08 tl type s brembo calipers 2 days ago with rotors. i figure that the tl and accord should have the same spindle and it should fit. so i took off the stock setup and remove the dust cover and try to see if the caliper will bolt on the spindle and the holes line up but the av6 calipers bolts are too small and so is the hole in the caliper bracket(spindle). so i put the rotor on and calipers held up by the av6 bolts and i try to put on the v6 wheels and i need a 5mm space but it looks like it will clear. now i looking for type s spindle off a tl to get the right bolts so i can bolt these on. also the brake line will bolt on. when i get the spindle i will post pics. so i need to powercoat my calipers and get spindle and boom write up
