well i trying to install my calipers today but i measure the ball joint and the accord is bigger than the type s and the upper ball joint and tie rod are both smaller than the type-s. plus i order the type s sway bar instead of tsx sway bar and guess what wont fit. today is a f!!!ed day. but i measure the calipers holes on the spindle of the accord and the hole has to be open up 1/8" more in diameter. plus from the the bottom caliper hole to the the outside of the hub is 1/4" more on the type s, so i figure to put on a 1/4 washer between the hub and rotor to sit right well try. unless i buy lower and upper control arms with tie rods off a type s
