1 - 6 of 6 Posts
i couldn't find anyone who did a weight comparison info so hope this helps anyone else looking to possible get a Carbon Fiber Hood in the future. sry for camera phone pics
1. OEM 2003 Accord 4dr Hood weighs in 32-33 pounds: (a guy who picked up my OEM Hood that same day so weighed/took pic that day)
2. underside of OEM Hood weighed without Hood Under Padding
3. Carbon Fiber Hood weighs in at 20 pds.
4. 10 pound weight plate to check accuracy
For anyone looking to get a Carbon Fiber Hood, the style i got was:
VSII-style carbon fiber hood for 2003-2007 Honda Accord 4DR
pic of what it looks like:
all CF Hoods should weight about the same so to shave 12-13 Pounds from the Front Engine Area is significant
even with things like lightweight battery or other lighter engine components, it'd be hard to get anywhere near that much within the same price range of a CF Hood
Relocating the battery to trunk, and the hood combined, would be great for the weight balance.
i think its worth it if your trying to shave 12 lbs. from the front end
the amount of money it would take to change certain Engine parts to lighter weight material, cost/benefit...its worth it
answering a PM on DA i got here so i don't have to double post it and its relevant for anyone who wants to consider all facets of going to Carbon Fiber
"Does the CF hood allow you to use the airlift or do you need to revert back to using a hood prop?"
yes, i was able to use the OEM airlifts and the Hood had predrilled holes and OEM sized 10mm hole slots for all Four Bolts.
i had in mine that i would have to go back to a Hood prop but as long as your not constantly swinging the Hood up, there shouldn't be any issues
i would NOT recommend ever using the Rear Shocks on any full sized Hatchbacks (certain cases like older Civics may be ok). when i had a Full Carbon Fiber Rear Hatch, i removed the OEM airlifts because the amount of pressure they provided to lift a OEM Full Rear Hatch, they can crack even the best of CF Full Rear Hatches
example of a Full Rear Hatch: (i wouldn't use Rear lifts even if instead of glass, went w/something light like Lexan:
Lexans great but never had actual experience w/not using the OEM Rear Defroster or using something else to defrost rear window in a true 4 Season state), example of Lexan but cost benefit of Rear Defroster is something to consider:
older Civics, still a Rear Hatchback but way less weight than above + OEM Glass or Lexan, etc:
on the Accord, this shouldn't be a problem if you went Full Rear Trunk. main issue here would be making sure your not constantly slamming the Rear Trunk. i found that you can literally bring the Trunk almost all the way close, then just gently tap close
i cringe when friends/family just drop the Rear Trunk lid even though i know its OEMand there shouldn't be any probs
hope this helps and feel free to PM/post w/any questions, concerns
SK8 OR DIE
Thanks for the detailed info. I recall having to find that on another forum (HT maybe), that my Seibon hood weighed about 15-20 lbs. I never actually weighed them when I did the swap unfortunately, because I was in a pinch and had it shipped to the body shop repairing front-end damage to my car at the time.
1 - 6 of 6 Posts
