1 - 7 of 7 Posts
What offset can you get for accord v6 coupe? what is offset? does it matter or is there only 1 specific offset that will work?
im thinking about getting 18 inch wheels for my car .. thanks
a member on this board has 8.5" wide wheels with 42mm offset on his 7th gen v6 coupe and the wheels are flush with the fender. I think you can go wider and have a lower offset on the 7th gens. Based on that I think you can get 8" wide rims with high 30's offset or 7.5" rims with low to mid 30's offset
Wheelgap = sleeper mod
I have aftermarket 17s with 215/50/17 tires and a 42mm offset and mine is fine. You probably want bigger wheels though.
18x8 with +48mm bolt patter 5x114.3
that's the size i think im gonna go with ... thanks for all the help!
1 - 7 of 7 Posts
