whats up guys? just saw this was a V6 site and figured i should register since i have one of the most famed (or feared) v6's out there
i have an '87 GN that is making between 450-500RWHP and 550-600 rwtq... not too bad eh?
i dont have any times on the car right now, but hopfully when it starts to cool down i will be able to go to the track... i am hoping for mid 11's
right now the car dosent have a tranny in it, i am building a new tranny for the car... i always have to do things the hard way.. lol
peace out
Sup dude? Awsome car. Only thing nicer for v6's IMO is a GNX. You building another 2004R?
Discussion Starter #3 (Edited)
yeah, you dont want to know how many problems i have had with the trans in this car....
a shop tryed building the transmission last november, but they kept having troubles with it.. and they ended up throwing half the stuff in the transmission away that is turbo buick specific... which is also worth big bucks... i was pissed... really pissed to say the least
so i got another 200-4R and figured i would rebuild it my self and save some money and know that it was getting done right. well the transmission that i built had a bad case and leaked all over the place. i thought the leak was coming from around the pan, i replaced that 3 times, then i thought it was the driveshaft seal.. then it goes on and on.. when there was no sign of the leak, i was all excited and i was like, hey hey, alright, i am going go see how the bad boy is.. i drive it around, stop off at a local car show and i guess somewhere on my way there it springs the leak again.. i pull into a parking spot (not knowing about the leak yet) call a friend, go to leave, put the car in reverse, no reverse :angry:
i limp the car home, pull the transmission and look at all my damage.. i burnt all the clutches and direct drum and foward clutch had seized up... oh well
and my orgional trans that the shop tryed building last novemeber, i had pulled that one apart a couple days before, and the thing was completely shot... direct drum and foward clutch BEARLY worked.. (and i was wondernig why the thing was flairing soo badly..) and all the clutces looked like onion rings that fell into the grease and were left there for a couple hours then pulled out.. it wasnt pretty
so now, i am awaiting another rebuild kit to get here so i can rebuild my orgional transmission and have my car back on the road again. hopfully the kit gets here today, if it does i am going to pull an all nighter to get that transmission together and get the tranny in tomorrow.
i miss driving my car...
oh well
and the only thing, about the GNX motor over the regular GN motor is the turbo had cermaic impeller wheels to the GN's steel impellers. they had a better chip, which allowed them to run more boost. (a stock GN makes ~13psi where a GNX is at ~16) they had a slightly bigger intercooler. but other then that, the motor was the same, some people believe they had different heads, but this is untrue.
but what the GNX did have, is that kick ass suspesion... i got to drive/ride in a GNX. i didnt do this, i was too scared to break the guys car.. but he launched the car and the ass of the car when he powerbraked it rose like 8 inches.. no kidding... really an impressive thing....
I just like how rare the GNX is, its like a speacial club once your in :D
I put a 2004R in my 79 c10 behind a 300hp 380lbs/ft small block. I bought a stage 2 unit from bowtie overdrives, supposed to take 450hp. So far so good, of course I don't beat on it at all :)
I highly doubt your going to get any 4sp auto to last behind your kind of power unless you go to a 4L80E. 500hp is usually the limit for built 700/200-r4 trannies. The 4L80E can take anything you got, and can be programed to shift exactly how you want, when you want, and as hard/soft as you want. Such a sweet tranny....of course its a really exspencive option but if you gota have a overdrive thats about all there is. O yeah you could build up a th350 or th400 [go with the 350, the 400 in built form will only take a little more power while robbing a lot more] and put a gear vendors overdrive behind it. Thats even more bulletproof then the 4L80E but also more exspencive probably and not as customizable.
Dam see what happens when I get going with domestics? I can't stop :D
a lot of people in the turbo buick community use the 200-4R, if you build it right, it can hold up to 9 second passes... i know a couple who have done it...
