What J-series pistons I can use to yield a higher compression in a 02 J32 engine?
Has anyone ever made aftermarket cams for the J-series engines?(no TL-S,please)
Thanks in advance,
Darvin
In a 02 J32 you can use the following, 05RL pistons and rings, they are factory forged and will yeild 11:1 compression, as far as cams, just get a set from a 03 CL-S, the 07 TL-S will not fit right in the 02 engine.
Thanks...
What about the KMS racing camshafts? Do you think it will make better power for N/A?
