1 - 4 of 4 Posts
I drive an 05 accord 2.4L auto VTI-EX. I noticed a while ago that my engine had lost compression and was losing oil a lot so I decided to throw in a new motor.
I purchased a new engine but later got to find out it was a K24A6 engine variant instead of a K24A4 like my last engine.
Now the car is having a permanent check engine light, scanned and got codes P0341 (camshaft position sensor A) and P0747 (Pressure control solenoid A stuck on).
It drives and isles different and erratically. If I switch on the air conditioning it vibrates so badly the entire car shakes or just stalls the engine.
I just want to know more about this engine as it’s past it’s warranty and I can’t return to the shop I purchased it from for an exchange.
Has anyone come across this variant of K24 engines before?
Yeah, that’s the JDM Odyssey engine. Are you sure you used the correct sensors from your old engine and whatnot? To be honest I have no idea if this engine would work or not, but I would have definitely tried to retain as many sensors and whatnot off the accord as I could, considering they may be different for that engine. As much as they may “plug” they may not “play” if you know what I mean. Again I’m not too familiar with that engine as it’s never came in anything else over here and there’s not much info on it.
1 - 4 of 4 Posts
