1 - 11 of 11 Posts
I drive an 04 accord coupe V6 sitting on 04 TL wheels 17X8 45 offset with stock 235/45/17. I found a set of used aftermarket rims 18X7.5 *40 offset* with 225/40/18 tires. My car is lowered to the point where theres no wheels gap front and back. Base on the amount of drop i have now and the TL wheels, will the aftermarket rims work without rubbing with such low offset????? I need to know before i buy it. thanx.
what effects will i have with 40 offset wheels like in steering, handling, braking, and accelerating?????
Discussion Starter #2
pls. i need to know. the guy (seller) wont let me try it on. Hes in a rush whoever gives him the money gets it, i want to get this so bad.
Hella Functional
it WILL rub for sure on a 6th gen, but for a 7th gen, there seems to be a little bit more space i nthe wheel well.
Ur handling won't really be that affected,
Shouldn't.
Regarding the effects on handling, not much - 45mm vs. 40mm is a 5mm difference. It will look better with the 40mm offset - flush.
Well i didnt get the wheels, i tried it on looked great but theres not enough room it will rub.
Thanx guys for you help.
WRONG it will not rub....and i kno that because i used to have 18x7.5 with 225/40 tires with +40 offset...and i did not rub...i was too lowered with no gap....now if u had 235 tires....it willl rub because of the wider tires...the rims would be flush....here is a pic...
Discussion Starter #9
Oh ok thanx accord03. I was the one who tried it on so i know better.
Why did you change the rims to stock CL wheels???
1 - 11 of 11 Posts
