1 - 9 of 9 Posts
I can't find the Firewall on my 94 ex. Do any of you know where I should be looking, or anyother place I can run wires from the battery to my trunk? I want to install an amp I just got in my trunk so I need to run the power wire and stuff. Thanks in advance!
the firewall is the wall at the end of your feet or back of the engine. try look for a holeand see if you can poke throught it with a screwdriverif not find a good spot and drill but know whats on the other side
Yeah, I knew what a firewall was, I just couldn't find it. But after a while of looking I finally found the stupid thing, it was behind my glove compartment, so i had to take that out so i could reach it. I had to run the wire over the front passenger tire well to get to the firewall, then down through the glove compartment and across the floor panels on the doors. Got it though, and the amp install looks great. Thanks!
thats what i done to my car. i had to drill through the firewall. just find you a nice empty area to drill through and you should be good to go.
Anyone got a wiring diagram? I need to install a remote door opener system for the car. I need to know the wires to the stock power lock switches. Thanks!
___________
1 - 9 of 9 Posts
