J32A2 6-Speed Rocks
hope someone can help me out with this. The new ones are just too expensive for me.
J32A2 6-Speed Rocks
yeah I have , but no luck
Just to make your job harder you want to get an ECU with at least one of the immobilizer keys that went with the car. Also make sure you get a receipt.
The reason for this is you will be able to start the car without taking it to a Honda/Acura dealer. To do that get a key cut for your car without an immobilizer then tape it to the immobilizer key from the donor car head to head. If you don’t do that a Honda/Acura dealer may not be able to reprogram the ECU for all keys lost as it requires the VIN of the donor car that could be removed from the Honda/Acura database. A Honda/Acura dealer should be able to add and delete keys if you have a working key.
