61 - 80 of 216 Posts
so does this mean that all the carbon that is not going back through the combustion cycle because of the EGR block off is going straight out the back... which might form faster deposits in your exhaust and down pipe... could this affect anything over time
Discussion starter · #62 ·
Well, if it did effect anything in the exhaust, which would you rather have, a engine full of extra re-burnt carbon all over you intake, valves and pistons which are big $$ to replace, or your exhaust......
Chill dude, who's the dumba$$? Didn't you read the effects of EGR as explained by people already? Do you know what an EGR does and doesn't do?
Long term effect: no exhaust soot build-up (carbon build-up can be caused by many other things). May fail smog. Will fail visual inspection and cause police hassle. No real performance gain.
That technical enough for you?
ban dumba$$
any update on how the egr mod is treatin ppl who have it? any noticeable differences in the long term?
There is a better place for you to post info about your purchase and plans for the new AV6. Also, please watch who you talk down to. If one of your first five posts is bashing a senior, valued member then your stay at v6p may not be pleasant.
^ hope this helps :up:
I will make these avalible to whoever wants one, the cost will be $100 shipped which will include new correct legnth bolts and new EGR valve gaskets. The inlet will be 1/2" hose mipple so you can connect it with eaither a simple breather element or route a hose to the intake. I will pull together a step by step when I install one on Kai's car this Satruday. The hardest part of the install will be removing the existing studs, you have to take the two nuts and lock them against each other on the stud by tightening them against each other and then trun them out like bolts. Anyone interested please PM me.
for posting your car's life story and irrelevant info on this thread to up ur post count.. yes ban. i know what a EGR does and wasn't directing my question toward you but to ppl who have this installed but thank you for the info :up:
Has anybody had this mod done up until now? It would be cool to hear some input from those who have had one installed for a couple months. It looks badass imo.
i think 3.56th gen had it along with one or two other ppl since the beginning of the thread. i'd like to see some intake manifold pics to see how little carbon is in there now
I opened up my IM a couple weeks ago when I adjusted my valves and there was remarkably little carbon compared to my old J30A1...maybe due to the Seafoam at 110k miles, but I have 145k now. I cleaned it out but there wasn't that much to do thankfully.
NVA-AV6, I'm interested in purchasing this mod for my car. What is the best way to get it? I work in Fairfax, VA, not sure how far that is from you. Also, would you suggest performing the EGR port cleaning TSB prior to installing your mod?
Sweet. Nice to meet you. I've been hanging around the forum for a few weeks now and learning a lot. Loudoun is 40 mins from my job but two hours from home in Spotsy. It's a trip but probably worth it. I guess when I'm ready I'll hit you guys up and make arrangements to pick up the EGR kit?
I am also interested in this, I am tired of my manifold getting to meat cooking temperatures and **** building up. Im going to strip my manifold bolts if i have to keep cleaning all the junk for Pete sake. Can i get a quote...i think you said 100 shipped last summer...still the same?
