OK, first I was reading up in the service manual about adjusting the valves (J30A4) on my 03 V6, and the Helm manual says to disconnect the Idle air control valve (IAC). Problem is, the exploded view in the manual shows nothing about an IAC valve, and I don't see one on the engine. I obviously can't disconnect something that's not there, but I'm wondering what's the deal here? Is the manual full of it, or am I blind?
While I have your attention, I've noticed a few threads about spark plugs coming loose from the heads on these engines, destroying the threads in the head, and causing some other damages. I don't remember any plugs being loose, when I changed them, but looking at the old plugs today, I noticed two of them were dirty, on the threads, and a little on the porcelain, so I suspect these plugs were starting to become loose. I was wondering if Honda has issued a TSB or something about this situation, and ways to prevent it? Thanks for any insight you may have on this.
