ok guys I been read all this front first page until last one and some make confuse me,ok I have 6speed MT from 7th accord and will bolt up to J32a2,J35a3 and J35a4.
just say,I want to take J35A3 or J35A4 and that engine I can get from oddy '02 - 04,right? and this some my question for MR.NVA-AV6 ( I knew it,you know alot about honda engine and I had been read on your project J35 with J32 block,that inspired me alot man but I don't want so complicate like on your project rebuild the engine,I just want to buy the whole engine and swap it w/o rebuild it ) This my question,
If I take J35A4 do I need change my header and catalytic like on your project?
can I use engine wire and ECU from accord '00-02' to use on J35A4?
If not, is it the accord dash wire connector to ECU will be fit on oddy ECU,like direct swap?
What the mount engine I should use? (like on your project or use OEM mount)
I have to use alternator from Oddys,is it direct swap on mount alternator and how about the conector wire?
I think Thats all question in my head right now and all input I would appreciated from any member specialy from nva-av6. Thanks everybody
